extreme egr guru needed
"Half that's missing" is not very technical - I don't know what you are saying. The EGR "system" consists of only one part - the EGR valve. That's it. It could be causeing a vacuum leak - the remedy for that is to remove and clean the valve, or replace it. It's really that simple.
Sounds like you are confusing "EGR" with the rest of junk in the engine bay that people mistakenly call "emmissions stuff". The only emmissions thing on an EA81 that will make any difference on a tail pipe test is the cat, and it's ASV system..... and you can pass without those pretty easily. You just need a tune up, and to fix all your vac leaks.
