Scoobywagon Posted July 22, 2004 Share Posted July 22, 2004 OK..working on the 83. 268 kilomiles. I recently had to replace both fuel filters, the fuel pump, most of the rubber fuel lines, coil, cap, rotor and wires. Now I've got something odd happening. It only occurs under a fairly specific set of circumstances. I have to have been driving steady at about 3000rpm. Speed doesnt matter, apparently. Anyway, run the engine at 3000rpm for a while, then load it up without giving it more gas. It will pick up an occasional miss that will get worse if you don't do something. If you floor it, the car will cough onvce more, then the problem goes away. The other solution is to simply disengage the clutch, let it drop back to idle momentarily, then back off the clutch and you're off again. The plugs are a mis-matched set (1 champion, 2 delcos and an autolite. not my doing, but there it is) with some wear on them, but they didn't look bad when last I had them out. I'll probably change them as I should have when I did all that other stuff. Does anyone else have any ideas about other things I should chase down? Link to comment Share on other sites More sharing options...
garner Posted July 22, 2004 Share Posted July 22, 2004 disrtibutor? advance unit? just a guess garner Link to comment Share on other sites More sharing options...
oddcomp Posted July 22, 2004 Share Posted July 22, 2004 sounds like my grandma's 90 caddy it loading up and can't burn all the fuel first off get all nice new ngk plugs in it then run around the block go buy a beer or someting at the minimart get home check and reset the timing if needed and change plug wires if you need to i paid 600 for my twagon cause it had a bad cap,rotor,wires. ran like hell oh and the coil tower had a crack in it letting it arc to the nearest ground it could find Link to comment Share on other sites More sharing options...
