swapping pully system
I would hold off on all of the pulley swappin until you know for sure that you can't read the marks on the flywheel with the different intake. One possible stumbling point could be with the A/C compressor. I'm pretty sure that XT's only came with the Hitachi A/C system. If your GL has one of the Panasonic systems or Nippondenso system, you may not be able to find a compressor or compressor pulley that will work with the different belts. The power steering and water pump pulleys should swap, I’m not sure if you can swap the alternator pulley hand have the correct alignment.
