Gee, at 1st Subaru Parts, it only costs $39.78, but then you'll need to add shipping, for me that would probably be less then the $4.00 difference. I need a clock for my Impreza, but I don't think this one would work, as I don't see anywhere that I could fit it.
Ouch! I had problems with my clock but $43 bucks for a new one??????
Using the fix outlined by board members, I had my old clock ticking in about 15 minutes.
Either, I'm cheap or that clock is expensive?
Glenn
82 SubaruHummer still has orignal clock
01 Forester still has re-soldered orignal clock
Glenn
I always thought the overhead clock was kind of useless, considering there's a clock on the radio as well. If I were to spend $35 to $43 bucks on a replacement, it would have to be a lot more than just a clock! Anyone ever replace it with something like an outside temp guage, trip computer, compass, etc?
Glenn
The clock is out on my Forester. What was the repair you refer to? I have power (12 volts) at the connector, but the clock module seems to be dead.
Thanks
Lemme do some digging......
I think I did a post, whinning about "clock issues". Do a search for those key words. The responses I got were 100% accurate even to the exact chip that needed a "booster" soldering. The guys here had this problem nailed.
I'm gonna go get lunch, if you havn't found it in an hour or so I'll get you the link, when I get food in me:D
Hungry,
Glenn
82 SubaruHummer with original clock
01 Forester with repaired original clock
