How Much to fix Computer in 2003 Baja?
I can't help with a price but ECU's can run over $600 dollars from a dealer. The ECU's are normally very reliable. Are you sure it is bad? Even if it is bad, the unit should be under warranty unless someone damaged it somehow.
