Hocrest Posted July 26, 2004 Share Posted July 26, 2004 Are the rear torsion bars interchangeable between all EA81's?? I need to get a new one for my Brat, could I also find pull one off of a hatch or wagon if they are in better shape? Quote Link to comment Share on other sites More sharing options...
Qman Posted July 26, 2004 Share Posted July 26, 2004 They are the same. I don't know if they are rated the same but the replacement torsion bars are the same part number between the Brat and the Hatchback. Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted July 26, 2004 Share Posted July 26, 2004 hmmm makes me think that the bars for the wagon could be a lil heavier in spring rate cause of the extra weightwouldn't you think so Ken? Quote Link to comment Share on other sites More sharing options...
Subi81 Posted July 26, 2004 Share Posted July 26, 2004 they probably just preload the bar more on the wagons comparied to the hatchs Quote Link to comment Share on other sites More sharing options...
PHATBRAT Posted July 26, 2004 Share Posted July 26, 2004 Dave, If you need one I know of the same BRAT with the good gas tank we could pull it off of there if you wanted. I would try a one of the BRAT's from Harry's first since that would be much cheaper. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted July 26, 2004 Share Posted July 26, 2004 so if i run EA82 coilovers on the rear of my brat, it is redundant with the torsion bars. can you remove the torsion bars and run without them? or just set them to do as little as possible? Quote Link to comment Share on other sites More sharing options...
