hklaine Posted July 27, 2004 Share Posted July 27, 2004 I am preparing to do my first clutch job, and have been reading up on others' experiences. I have seen quite a few of you mention the "oil separator plate" and the replacement of plastic with metal versions. However, all the discussions I have seen tend to be based around the 2.5L engine. Does my 2.2 also have this separator? If so were they also shipped with the plastic version that should be swapped out? I would like to round up all the parts ahead of time, as this needs to be a one-day job so for $15 I'll pick one up if I might need it. Anyone had experience? So far my list includes the following: rear seal bearings (pilot/throwout) disc pressure plate exhaust manifold gaskets Anything else? Do the rear cam seals need to be done? If so I am assuming this would be the time to do them? BTW car has 110k. Thanks. -Heikki Link to comment Share on other sites More sharing options...
alexk02 Posted July 27, 2004 Share Posted July 27, 2004 I just had it done on my 1999 Legacy L wagon. The separator plate was plastic, so thanks a bunch for the good advice I got here. One more part I'd add would be the clutch cable (if your car has cable operated clutch vs hydraulic one). Link to comment Share on other sites More sharing options...
hklaine Posted July 27, 2004 Author Share Posted July 27, 2004 Would you happen to have the receipt with a part number handy? Wondering if it is the same as the 2.5L. I am assuming yours was replaced with the metal separator? Thanks. -Heikki Link to comment Share on other sites More sharing options...
alexk02 Posted July 27, 2004 Share Posted July 27, 2004 Heikki, sorry I don't have it handy, but call www.1stsubaruparts.com and ask them if they have it for your car. I remember it was $13-$15 or so. I am happy with the prices and expertise I get from these guys. Link to comment Share on other sites More sharing options...
theotherskip Posted July 27, 2004 Share Posted July 27, 2004 There are no rear cam seals - only small caps that you can reseal with permatex ultra-grey. but to do that you need to remove the valve covers, which you won't be doing for the clutch. you may add a clutch fork boot. mine crumbled when i removed mine, and the dealer had to order a replacement. it is not a big deal, as you can reassemble it without it and just put it on when you get a chance to pick one up. are you planning to have the flywheel machined? well worth it IMO... Link to comment Share on other sites More sharing options...
