idahotroy Posted July 27, 2004 Share Posted July 27, 2004 Hello, I have a 1987 GL-10 that I love. However, like many others the air ride is shot. When I first bought the car there was a step by step artical on the conversion. Does anyone still have that. I am trying to find a list of replacement parts needed as well Thank You Troy Link to comment Share on other sites More sharing options...
Will Smith Posted July 27, 2004 Share Posted July 27, 2004 we used to just put standard shocks and struts in. it was that simple. Link to comment Share on other sites More sharing options...
calebz Posted July 27, 2004 Share Posted July 27, 2004 My 87 used to be an air ride car too. There really isn't a need for a write up.. Unbolt the air ride shocks/struts Bolt in the standard ones 2 bolts and 3 nuts each for the front, 3 bolts each for the back. Link to comment Share on other sites More sharing options...
hush777 Posted July 27, 2004 Share Posted July 27, 2004 Welcome to the board. Had the same problem with a turbo wagon gl-10. We got parts from a junk yard in oregon (west on the interstate of Boise) Still have all the air ones and the parts. (Left rear went out) You can try going to www.car-parts.com and looking for the parts to do the conversion. Air compressor is located behind the right front fender (access through the plastic above the wheel) and the computer is under the drivers seat. What part of Idaho are you in/from? I'm in boise county. Hush Link to comment Share on other sites More sharing options...
MilesFox Posted July 27, 2004 Share Posted July 27, 2004 if youre gonna start by buying NEW struts, make sure you come up with strut caps and springs too, as well as the proper tools. if you pull them out of the junkyard the strut will obviously be assembled with the caps and springs-direct swap in Link to comment Share on other sites More sharing options...
idahotroy Posted July 28, 2004 Author Share Posted July 28, 2004 hush777 said: Welcome to the board. Had the same problem with a turbo wagon gl-10. We got parts from a junk yard in oregon (west on the interstate of Boise) Still have all the air ones and the parts. (Left rear went out) You can try going to www.car-parts.com and looking for the parts to do the conversion. Air compressor is located behind the right front fender (access through the plastic above the wheel) and the computer is under the drivers seat. What part of Idaho are you in/from? I'm in boise county. Hush I am in Boise. Where are you in Boise County Link to comment Share on other sites More sharing options...
hush777 Posted July 28, 2004 Share Posted July 28, 2004 idahotroy said: I am in Boise. Where are you in Boise County Lowman Private Message me with your phone# if you want to get in touch. in HSB right now and headed for Boise. Hush Link to comment Share on other sites More sharing options...
Hondasucks Posted July 30, 2004 Share Posted July 30, 2004 you could also just go to a JY and find a good air shock.. Just use a bike pump with a pressure gauge and see if it will pump up. If so, extend the shock fully and apply silicone grease to the area where the bag sits (It rusts out and puncures the bag) Link to comment Share on other sites More sharing options...
