Hocrest Posted July 27, 2004 Share Posted July 27, 2004 I have not quite a half full tank of gas in the Brat. I want to empty it out so I can pull the tank out while I'm having my diff issues. Is there a way to use the pump and filter and just disconnect a hose somewhere and pump it into another container?? Or, should I just siphon it out? I would like to run it through the filter so I can safely use it elsewhere... Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted July 27, 2004 Share Posted July 27, 2004 well just clean the underside of the tank and there should be a bolt on the bottom of the tank near the center of the lowest part of the tank just put something under that and take the bolt out just be careful to make no sparks and have no open flame around and also recommend wearing some nitrile or chemical gloves and also some chem goggles or at least some safety glasses Link to comment Share on other sites More sharing options...
subiemech85 Posted July 27, 2004 Share Posted July 27, 2004 you can pump it out, as far as where to disconnect the line, that is up to you, after the pump,or before the carb Link to comment Share on other sites More sharing options...
Qman Posted July 28, 2004 Share Posted July 28, 2004 Take the bolt out. Use cheesecloth to filter the dirt that may be in the tank or around that may fall into things. Safer than using a pump. Just need a gas can close to the amount of gas left in tank. Then get a large funnel. I have one that has about a 12" diameter but the nozzle end fits into the gas can. Link to comment Share on other sites More sharing options...
