kjadams2 Posted July 28, 2004 Share Posted July 28, 2004 I have a 99 Legacy Outback. Anyone? Link to comment Share on other sites More sharing options...
99obw Posted July 28, 2004 Share Posted July 28, 2004 Any parts store should have them. They should have different sizes for different size vehicles. Just ask for a small one. Be very careful when making the connections. Make sure you get the cooler plumbed in the return line from the radiator. Be aware that the mounting system they use can rub a hole in the radiator. Link to comment Share on other sites More sharing options...
Tiny Clark Posted July 29, 2004 Share Posted July 29, 2004 If I installed a cooler, I would completely disconnect the radiator cooler. Link to comment Share on other sites More sharing options...
jcniest5 Posted July 29, 2004 Share Posted July 29, 2004 Tiny Clark said: If I installed a cooler, I would completely disconnect the radiator cooler. I found it easier to leave the radiator part alone, then use an adapter (or just a hose) to link the two of them together. So, it goes like this: Hose from tranny goes into radiator, out (of the return port) into the new cooler, then out (from the cooler out port) into the tranny on the return hose. Link to comment Share on other sites More sharing options...
Olnick Posted July 29, 2004 Share Posted July 29, 2004 I found the best price at a place called Makco Distributing, Inc. Look under bulkparts.com. Was around $30. Shipping was fast. Got it for my wife's Nissan Maxima but haven't installed it yet--I refuse to "tie" it to the car's radiator. Am going to fabricate a support so it is freestanding in front of the rad. By the way, there are good arguments for plumbing the auxiliary cooler in series after the car's radiator rather than bypassing it. Link to comment Share on other sites More sharing options...
Subie Gal Posted August 3, 2004 Share Posted August 3, 2004 www.summitracing.com tons of generics to choose from Jamie Link to comment Share on other sites More sharing options...
slo5oh Posted August 3, 2004 Share Posted August 3, 2004 I'm no novice, but I'm no expert either. Why does a subaru auto trans need a cooler? Are there problems with them overheating? I know what a trans cooler does, just wondering in this application. Link to comment Share on other sites More sharing options...
99obw Posted August 3, 2004 Share Posted August 3, 2004 Nearly all auto trannies can benefit from a cooler. Most cars run the fluid through a cooler integrated into the radiator, which limits the minimum tranny fluid temperature to approximately the coolant temperature. Auto trannies will last longer if the fluid is cooled to a lower temperature, and often during towing or heavy use the integrated cooler won't keep the fluid temperature low enough. Link to comment Share on other sites More sharing options...
Ranger83 Posted August 3, 2004 Share Posted August 3, 2004 Just about any automotive radiator shop will install one at reasonable cost. Many trailer shops and UHaul trailer centers will install them as well. Link to comment Share on other sites More sharing options...
