RodA2003 Posted July 30, 2004 Share Posted July 30, 2004 Is it true that for 97 Outbacks with AT at least, there is no center differential? In looking at http://www.endwrench.com/pdf/drivetrain/Ft4EATTransmissionsW98.pdf there is a description of the muti-plate clutch pack (MPT) that says how the duty solenoid determines the amount of AWD. It also says that the power to the rear goes from the reduction power shaft through the MPT to the rear drive shaft. There is no mention of a center differential anywhere. I think others have suggested that the MPT (or viscous coupling for MT cars) performs a limited slip operation for a center diff, but that doesn't seem to be true. R Link to comment Share on other sites More sharing options...
myles Posted August 1, 2004 Share Posted August 1, 2004 Is it true that for 97 Outbacks with AT at least, there is no center differential? In looking at http://www.endwrench.com/pdf/drivetrain/Ft4EATTransmissionsW98.pdfthere is a description of the muti-plate clutch pack (MPT) that says how the duty solenoid determines the amount of AWD. It also says that the power to the rear goes from the reduction power shaft through the MPT to the rear drive shaft. There is no mention of a center differential anywhere. I think others have suggested that the MPT (or viscous coupling for MT cars) performs a limited slip operation for a center diff, but that doesn't seem to be true. R Correct, there's no center diff. in your car. Link to comment Share on other sites More sharing options...
THAWA Posted August 1, 2004 Share Posted August 1, 2004 Of course there is a center differential, how else are both your front wheels and your rear wheels getting power. Just because it doesnt have a gearset doesn't mean it isn't a differential. That'd be like saying an automatic isn't a transmission because it doesn't have gears. Link to comment Share on other sites More sharing options...
DerFahrer Posted August 1, 2004 Share Posted August 1, 2004 THAWA is correct. It's a differential because of what it does, not because of what it is. A very unconventional differential, but a differential nonetheless. Link to comment Share on other sites More sharing options...
RodA2003 Posted August 2, 2004 Author Share Posted August 2, 2004 Agreed, the MPT does the equivalent of a limited aspect of a mechanical differential, but it is lacking other features normally considered part of a differential: 1. An input shaft with two driven output shafts. 2. An inbuilt gear reduction. 3. Neglecting very small frictional losses, the input power equals the sum of the power from the 2 drivern shafts. This last point is important. With friction plates or viscous couplings, the differential in power between input and output is all wasted as heat, and not used to propell the car. So I think it is very misleading terminology to call such devices differentials. See also http://www.car-videos.com/whatis/differential.asp Link to comment Share on other sites More sharing options...
myles Posted August 3, 2004 Share Posted August 3, 2004 Of course there is a center differential, how else are both your front wheels and your rear wheels getting power. Just because it doesnt have a gearset doesn't mean it isn't a differential. That'd be like saying an automatic isn't a transmission because it doesn't have gears. But an automatic _has_ gears (kick-rump roast planetary gearsets, at that!) The MPT isn't any more a differential than your manual transmission's clutch is a differential. Link to comment Share on other sites More sharing options...
