tracedog67 Posted August 3, 2004 Share Posted August 3, 2004 Fellers, 1997 OBW, 5 MT, 227k miles, I pulled into the entrance of our subdivision (thank goodness) and my clutch stayed on the floor, it wouldn't come back up. I know I have lots of miles on this car but the first owner drove 70 miles one way to work everyday so the miles are mostly highway. I had a clutch go out before on a Tbird turbocoupe so I know the signs of a clutch going out. The OBW shows no signs of the clutch giving out, is there a return spring of some kind that may have broke? Please help i'll be stranded at home tomorrow if I don't figure this out. After just shelling out $400 for exhaust work on our SVX I don't want to have to put more into another car after I got the OBW running great with new headgaskets and such. thanks for this board. Tdog67 Link to comment Share on other sites More sharing options...
RallyKeith Posted August 3, 2004 Share Posted August 3, 2004 Fellers, 1997 OBW, 5 MT, 227k miles, I pulled into the entrance of our subdivision (thank goodness) and my clutch stayed on the floor, it wouldn't come back up. I know I have lots of miles on this car but the first owner drove 70 miles one way to work everyday so the miles are mostly highway. I had a clutch go out before on a Tbird turbocoupe so I know the signs of a clutch going out. The OBW shows no signs of the clutch giving out, is there a return spring of some kind that may have broke? Please help i'll be stranded at home tomorrow if I don't figure this out. After just shelling out $400 for exhaust work on our SVX I don't want to have to put more into another car after I got the OBW running great with new headgaskets and such. thanks for this board. Tdog67 I know this might sound stupid, but did you try pulling it back out? I know that at some point Subaru went to Hydraulic clutches. If your car has a hydraulic clutch then there is the possibility of the pedal traveling far enough that a spring somewhere doesn't do it's job and the pedal stays. All I've ever done when that happened was reach down and pull the pedal back. Keith Link to comment Share on other sites More sharing options...
rweddy Posted August 3, 2004 Share Posted August 3, 2004 Fellers, 1997 OBW, 5 MT, 227k miles, I pulled into the entrance of our subdivision (thank goodness) and my clutch stayed on the floor, it wouldn't come back up. Tdog67 Clutch Master Cylinder This is not that big of a fix, you can rebuild it yourself or get a rebuilt one. Link to comment Share on other sites More sharing options...
hohieu Posted August 3, 2004 Share Posted August 3, 2004 Do title search for "clutch pedal" and you'll see some threads on clutch pedal sticking (down to the floor). It's probably a hydraulic issue, not a mechanical one. Link to comment Share on other sites More sharing options...
canajun2eh Posted August 3, 2004 Share Posted August 3, 2004 When that happened on my 92 Legacy, it was a broken clutch cable. I don't know whether your car has a hydraulic clutch or a mechanical one. Link to comment Share on other sites More sharing options...
nickb21 Posted August 3, 2004 Share Posted August 3, 2004 This might help, if copy and paste works.. http://pub205.ezboard.com/fultimatesubarumessageboardsthenewgenerationofsubarus.showMessage?topicID=7875.topic Link to comment Share on other sites More sharing options...
sprintman Posted August 3, 2004 Share Posted August 3, 2004 I had same problem. Free slave cylinder etc under the TSB. They gave me a new clutch free earlier as well. Good luck! Link to comment Share on other sites More sharing options...
tracedog67 Posted August 3, 2004 Author Share Posted August 3, 2004 Clutch Master Cylinder This is not that big of a fix, you can rebuild it yourself or get a rebuilt one. The master cylinder was a little low of DOT 3 so I filled it up but the slave cylinder ( I assume this is the very small 3/4" cylinder with a small rod coming out of it) doesn't seem to want to go back each time. Yes, I can pull the clutch up with my foot but if I turn the ignition on it does it again. BTW, my wife drove the car yesterday and she hasn't drove a stick for years ( I hope she doesn't read this or Mr. Happy will be on bread and water for a month). Keep the suggestions coming please, where do i get these parts quickly. thanks Tdog Link to comment Share on other sites More sharing options...
DerFahrer Posted August 4, 2004 Share Posted August 4, 2004 I hate to say this, but it sounds like the pressure plate kicked the bucket. Regardless of how it was used, 227,000 miles is a lot for a clutch. Be happy it went that far. My Legacy clutch went from driveable to undriveable in 6 miles, the release point being on the floor. When I pulled it into the mechanic the next day, the pedal stayed on the floor. I'm not ruling out a hydraulic issue, it's entirely possible. But it does sound to me like new clutch time. Link to comment Share on other sites More sharing options...
tracedog67 Posted August 4, 2004 Author Share Posted August 4, 2004 When I opened the hood i noticed that there appeared to be some wetness near the firewall. With the hood up I pumped the clutch and noticed something spraying on the windshield. My wife pumped the clutch and I was relieved to see that the hydraulic hose has a leak in it near the end of the coupling, so I hopefully just need a new hose. Is there an easy way to get this part, do you think some kind of tape would hold it until a new hose can be found? thanks for the quick responses Tdog Link to comment Share on other sites More sharing options...
sprintman Posted August 4, 2004 Share Posted August 4, 2004 The TSB applied to slave cylinder and hose etc. Not sure if that covers 97 model though. Link to comment Share on other sites More sharing options...
