TheMeatWagon Posted August 4, 2004 Share Posted August 4, 2004 Okay so ive been drivin my car and never once have i seen the green turbo light light up behind the turbo... So today im workin on the car and there are like 6 different vacuum lines all disconnected from the previous owner. The car still runs with em disconnected but i wanna get em put back to make sure they arent causing a problem. Ill take a picture of em when i get my digicam back and ask you guys if you know where they go. Anyone have a pretty complete vacuum diagram? Or maybe just a pic of the front passenger side of the engine bay where that cluster of hoses is from an 86 gl tubo coupe? Anyways so we were messin around changing the hose configurations and this one time a hose was connected i revved up the engine and for the first time ever saw the little green turbo light behind the word turbo light up to the bottom left of the speedo... whats this mean? Anyone? thanks Link to comment Share on other sites More sharing options...
hush777 Posted August 4, 2004 Share Posted August 4, 2004 It means a pressure sensor is sensing boost pressure. I'll have to look and see if I have a hose routing diagram for an 86. Hush Link to comment Share on other sites More sharing options...
TheMeatWagon Posted August 4, 2004 Author Share Posted August 4, 2004 soo the green light is a bad thing? And thanks for tryin to get me a vac diagram Link to comment Share on other sites More sharing options...
Turbone Posted August 4, 2004 Share Posted August 4, 2004 It means the turbo is putting out boost, you ninny Link to comment Share on other sites More sharing options...
TheMeatWagon Posted August 4, 2004 Author Share Posted August 4, 2004 Thats what i thought at first but then why have i never ever seen it before... weird... Link to comment Share on other sites More sharing options...
Turbone Posted August 4, 2004 Share Posted August 4, 2004 Thats because it was disconnected and you got it hooked up now. If you have more questions about Turbo's, I would suggest this web site for some good reading. How Stuff Works Link to comment Share on other sites More sharing options...
TheMeatWagon Posted August 4, 2004 Author Share Posted August 4, 2004 Awww i know how a turbo works im not that young... i just didnt know what the green light meant and if by him saying it means its showing pressure i wondered like if it meant excess pressure. The vac hoses we hooked up didnt have much to do with the turbo at all i dont think and when they were connected it totally bogged the engine so we disconnected em again. Oh well... what do your guys turbos usually put out as far as PSI? Mine is doin 7-8 psi. Link to comment Share on other sites More sharing options...
calebz Posted August 4, 2004 Share Posted August 4, 2004 7-8 is stock boost Link to comment Share on other sites More sharing options...
TheMeatWagon Posted August 4, 2004 Author Share Posted August 4, 2004 Well its a stock turbo so i guess it fits quite nicely huh . Thanks man Link to comment Share on other sites More sharing options...
84Scoobaroo Posted August 4, 2004 Share Posted August 4, 2004 Still want that VAC diagram, Meat? Edit: dont know if it will help.. let me know.. Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted August 4, 2004 Share Posted August 4, 2004 well that is meaning that it's the stock setup if you want to (and at your age I wouldn't recommend it though cause of the blue light force might go after ya unless you are driving responsibly) you can do a few modifications to up the boost and the max I would recommend for street is 10 psi and if it's going to be raced only (what I mean is racing off the street and in a sanctioned event) then 12 to 14 psi is possible before you start destroying things. oh yeah and also might run super in that rig so you don't blow it up or overheat it Link to comment Share on other sites More sharing options...
TheMeatWagon Posted August 4, 2004 Author Share Posted August 4, 2004 Ahh yeah theres a lot of loose hoses floppin around under the hood so if you got one it would be much appreciated. And i think ill leave the turbo alone for now as i still am learning to rally and i dont need more power . As soon as i am a little more experienced and i get the engine tuned and running 100% then ill start uppin 115 horses of raw fury. Its not a matter of me being a safe driver, because i am, its just that i suck haha... only had my license for a couple months now. Still want that VAC diagram, Meat? Edit: dont know if it will help.. let me know.. Link to comment Share on other sites More sharing options...
subyrally Posted August 4, 2004 Share Posted August 4, 2004 concentrate on handleing and learning to control your car, then you start improving engine performance. that way, you should be able to get yourself outta most situations caused by extra power. that and you will be a better driver for it. Link to comment Share on other sites More sharing options...
tizzle Posted August 4, 2004 Share Posted August 4, 2004 Does anyone else find the turbo light to be a little too bright? I like it, but I also like not burning holes in my retinas. Link to comment Share on other sites More sharing options...
MorganM Posted August 4, 2004 Share Posted August 4, 2004 The light is telling you BOOST IT HARDER Link to comment Share on other sites More sharing options...
nkx Posted August 5, 2004 Share Posted August 5, 2004 my shift light blinds me a bit more than my turbo light Link to comment Share on other sites More sharing options...
calebz Posted August 5, 2004 Share Posted August 5, 2004 Shift light? where? Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted August 5, 2004 Share Posted August 5, 2004 I had a Jimmy that did that stupid shift thing even in 5th (of course I was in 4lo when it did that lol) Link to comment Share on other sites More sharing options...
nkx Posted August 22, 2004 Share Posted August 22, 2004 oops... aftermarket shift light. Link to comment Share on other sites More sharing options...
