Noisy EJ251 in '05 Outback
2005 OB. Original engine pulled*; installed an EJ251 (no history) with the proper parts from the '05 - Cam and Crank sprockets and IM, etc.
Got this noise on the Driver's side: https://youtube.com/shorts/_SV_YqaVGrs?si=RR28wJ05PoxhatR5
and from underneath: https://youtu.be/Kv8IuDBbvFw
- I set the valve clearance (on all the valves), which made no difference.
 - Pulled the injector's wiring on both Driver's side fuel injectors - no difference.
Other info.
- Drive's OK - power seems normal - for a 2.5.
- Get a CEL for P0420 after 2 drive cycles, which I've not diagnosed. Using this for reference: https://www.subaruoutback.org/threads/p0420-diagnosis.49537/
I had a similar noise in a '96 Legacy that turned out to be a stuck piston ring. https://www.ultimatesubaru.org/forum/topic/154755-swapped-out-the-hlas-for-slasstill-got-the-tick/
Is that Rod Knock? Wrist Pin? Stuck Ring(s)? Etc.
Thanks for the feedback.
* Original EJ253's tensioner bolt broke and caused valve/piston damage.
Edited by wtdash
^Thanks for the reply.
It's RPM dependent - cold and warm - it changes w/the idle speed - and isn't any worse sounding when revved - even to 6K.  And is concentrated over Cylinder 4 area.
Above (in my post) is cold start. Here is the warmed-up:
Edited by wtdash
