foxgap Posted September 24, 2023 Share Posted September 24, 2023 2006 Legacy Outback. When the windows are part to full down the glass rattles when the doors are closed. What do I need to do to tighten up the glass once I have the door panels off. Will I need parts that I can order ahead of time, I am sure the wife will not like driving around without door panels.... Thanks in advance for all your help, again. Mark Link to comment Share on other sites More sharing options...
lmdew Posted September 26, 2023 Share Posted September 26, 2023 Best option is to go to a yard and pull a door apart there. The top rub pads can usually be adjusted but they push the glass out. You may create wind noise. A good inspection is the place to start. Link to comment Share on other sites More sharing options...
