wtdash Posted November 15, 2023 Share Posted November 15, 2023 (edited) 1998 Forester, 267K miles. This part: -Edit: 12/3/23. It's the spade connector at the gauge. I pushed it (not sure it actually moved) and the gauge started to work. Weird as I'd done that before and no change at the gauge. About a month ago, It stop working consistently. Go up to the normal -just below half setting- and then drops all the way down. And this last week nothing - doesn't budge. I've tried two other senders - one used and one new - and they both worked initially, but then nothing the next day I checked it. I've visually checked the wiring which appears fine. Does the dash cluster gauge ever fail? I've never come across this issue and only pulled one cluster on a '96 Legacy, so not sure if the gauge section is even accessible? Maybe a solder joint has gotten weak, etc? Thanks Edited December 4, 2023 by wtdash Link to comment Share on other sites More sharing options...
lmdew Posted November 15, 2023 Share Posted November 15, 2023 I forget if you ground it I think it goes full hot. You can check the resistance and see what it does with increase of temperature. 1 Link to comment Share on other sites More sharing options...
