Where do you get your starter solenoids?
9 hours ago, czny said:
The solenoid contacts are the same as Toyota 20 & 22R starter solenoids. It's the bendix gear and motor that are different in rotation.
Somewhere in USMB history I made a post about this same subject. There it is!
https://www.ultimatesubaru.org/forum/topic/167347-86soob-wont-start/?do=findComment&comment=1387840
But the solenoid doesn’t have any bolts or screws, this one is crimped and pressed together. It doesn’t look like it can be disassembled.
You may have to buy the whole replacement solenoid then. Or cut the end cap off with a cutoff wheel & die grinder, put a contact, brush and end gasket on it (?)
Is it a cast solenoid body?
I did a search for solenoid contacts on fleabay and there just weren't as many valid results that I remember in 2018.
Maybe a search for Toyota forklift starter parts too?
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2332490.m570.l1311&_nkw=denso+starter+rebuild+kit&_sacat=0
Edited by czny
Here's an EA82, ER27 (XT6) solenoid. OEM looks the same with the crimped casing:
https://www.ebay.com/itm/224219322935?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20230811123856%26meid%3Da63accd2079a4c188a89dfcb86847b4d%26pid%3D101770%26rk%3D1%26rkt%3D1%26itm%3D224219322935%26pmt%3D1%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2&_trksid=p4375194.c101770.m146925&_trkparms=parentrq%3A2782821b18c0a8d8e9dc1a51fffee416|pageci%3A6d8c20d9-9099-11ee-9a94-5a1bd6dadb96|iid%3A1|vlpname%3Avlp_homepage
The Ebay solenoids I've bought for tractors are similarly priced and cheaply made (shocker!). Rebuild OEM is preferred but there may not be an option except $150 for a new one which is part number   23343AA090.  Interesting how some Subaru models are rebuildable or parts aren't carried and other models have all the bendix gears, tabs, levers, etc.
https://estore.subarupartswarehouse.com/p/Subaru_1996_Impreza/Starter-Solenoid/49233322/23343AA090.html
This shows same 90's impreza/outbacks being the same solenoid so I may scour some pull it yourself yards close to my christmas holiday travels if I can sneak away and the weather isn't nasty.
