Groucho Posted December 24, 2023 Share Posted December 24, 2023 hey! i’m finishing my ea to ej swap and wondering if anyone has recommended an aftermarket baffled fuel tank that fits the gl wagon? i replaced the fuel pump & lines and i’m worried that the more powerful pump will cavitate with a 1/2 empty tank, especially uphill. thoughts? thanks, groucho Link to comment Share on other sites More sharing options...
moosens Posted December 25, 2023 Share Posted December 25, 2023 (edited) Sorry, I had a post thinking your old tank was rotting. Fuel cell ? Edited December 25, 2023 by moosens Link to comment Share on other sites More sharing options...
el_freddo Posted December 25, 2023 Share Posted December 25, 2023 Get a fuel tank from an EFI model - the SPFI or GL-10 will have the baffled tank you’re after. At half a tank you won’t have an issue, below quarter of a tank you might though. If you can’t get a baffled tank go for a surge tank/swirl pot setup between the factory tank and the EFI pump. It doesn’t have to be huge but you will need your stock Fawcett pump between the factory tank and the surge tank/swirl pot and have the fuel return go to the surge tank/swirl pot and its overflow going to the factory tank. Or just keep your fuel tank above a quarter all the time (personally I suck at this and for some reason enjoy running my fuel tank low low low). Cheers Bennie Link to comment Share on other sites More sharing options...
Groucho Posted December 26, 2023 Author Share Posted December 26, 2023 (edited) thanks bennie! yeah, that’s kinda looks like what my options are .. $1000 fuel cell, $500 surge pump setup. actually i think you gave me the answer i needed- junkyard EFI tank. hmmm Edited December 26, 2023 by Groucho Link to comment Share on other sites More sharing options...
el_freddo Posted December 26, 2023 Share Posted December 26, 2023 $500 surge tank… whaaat? You’re not needing a race spec surge tank! Get one off ebay, it shouldn’t cost anywhere near $500 and if you’re fitting it yourself you won’t need much other than some time and maybe a bracket once you work out a mounting location. Or if you’ve got a mate that’s a welder get them to make one up for you - it doesn’t need to be a huge capacity, a litre should easily do the job. Cheers Bennie Link to comment Share on other sites More sharing options...
Crazyeights Posted December 31, 2023 Share Posted December 31, 2023 I have an 83 GL wagon and a 92 Loyale wagon. I EJ22 swapped both cars over 10 years ago and they both run great on the stock tanks. The fuel tanks aren't that big so I try not to run them low. Link to comment Share on other sites More sharing options...
