BlueRidge Posted March 3, 2024 Share Posted March 3, 2024 Good afternoon! I've found the rodent damaged wires, it's on the four-wire plug leading into the passenger side fuel injector port. I'm guessing it's the fuel pressure sensor. The rodent not only chewed through the wires but it took off with a three inch strand. I'm looking at needing to splice in a replacement wire. I have no clue what gauge wire will be needed for the splice. It's stranded wire. I've attached a picture below - any knowledge on this wire gauge? Thanks in advance Link to comment Share on other sites More sharing options...
brus brother Posted March 4, 2024 Share Posted March 4, 2024 I'm only guessing 18 gauge. Take wire to HD or Lowes and compare size with wire stripper? Link to comment Share on other sites More sharing options...
czny Posted March 4, 2024 Share Posted March 4, 2024 https://wetechnologies.com/technical-info/Stranded Wire Chart.pdf Compare your wire to fractional small drill bits to gauge the wire, if you don't have inch calipers. Link to comment Share on other sites More sharing options...
