bofus86 Posted March 7 Share Posted March 7 08 forester with p0026 error code. replaced ocv and solenoid. also cleaned the filter screen inside the housing those sensors reside in and made sure it was aligned properly. after new oil and filter i still get the same error code. not sure what the next step would be. i am wondering if genuine subaru ocv and solenoid would make a difference? Link to comment Share on other sites More sharing options...
lmdew Posted March 7 Share Posted March 7 Did you check the solenoid operation jumping the pins to power and ground? How's the harness look? Link to comment Share on other sites More sharing options...
bofus86 Posted March 7 Author Share Posted March 7 no i didn't. I'm not really sure how to do that Link to comment Share on other sites More sharing options...
idosubaru Posted March 7 Share Posted March 7 Check wiring for rodent or prior engine work damage - just the exposed, easily visible wiring, that's what they'd typically find first as well. Follow the wire back from the solenoid as far as you can. Are you sure you're addressing the correct side, there's two right? Make sure you're looking at the right one. Link to comment Share on other sites More sharing options...
lmdew Posted March 8 Share Posted March 8 You can just jump the pins to Power and ground. If you have an old Subaru connector you can pull the sockets out of that is idea. Should click when powered. Link to comment Share on other sites More sharing options...
