lmdew Posted March 22, 2024 Share Posted March 22, 2024 A friend has a 99 Forester and he wants to change the front hub bearings. The NAPA with a machine shop closed. No hydraulic press available. What Hub Tamer do you like? Anyone close to Colorado Springs, Colorado with one? Thanks, Larry Link to comment Share on other sites More sharing options...
89Ru Posted March 23, 2024 Share Posted March 23, 2024 If you have the space, a 20 ton press from harbor freight is handy for older wheel bearings, I've done a few. There's a used KD hub tamer on Ebay, might be missing the two-jaw puller, same set also on CL for over a month, but I've not used one before. 1 Link to comment Share on other sites More sharing options...
turboguzzi Posted April 4, 2024 Share Posted April 4, 2024 when i was poorer i made my own with a piece of thick wall pipe, some drifts done on a lathe and the biggest threaded rod i could find, think it was a M14 or M18. it wasnt fun, a bit sketchy too, but it did the job, Where there's a will, there's a way 1 Link to comment Share on other sites More sharing options...
