LeDevil Posted August 7, 2004 Share Posted August 7, 2004 Ok I just got my car today and it's throttle pedal is hard to push but once you get it past a certain point it loosens up like it is snagged on somethign I looked around and couldnt find anything so any ideas Thanks -LeDevil Link to comment Share on other sites More sharing options...
dave valiant Posted August 7, 2004 Share Posted August 7, 2004 You should check and see if your throttle cable needs adjusted.The 88 TBI wagon I just got from Chef_Tim had alot of slop in the throttle cable.I could push the pedal down a little and it wouldn't increase rpm so i adjusted the cable and it responds much better.It could be frayed inside the sleeve and that is why it binds.I would check the slop before I replaced it.Dave Link to comment Share on other sites More sharing options...
LeDevil Posted August 7, 2004 Author Share Posted August 7, 2004 Cool thanks I'll do that -LeDevil Link to comment Share on other sites More sharing options...
