linkthehero1234 Posted June 11 Share Posted June 11 Is it possible to use the gas pedal from an XT6 with the brake/clutch assembly from a newer EJ car? Or, can an EJ gas pedal mount to the brake/clutch pedal assembly instead of the floor? Also, how hard is it to move the throttle cable down a few inches on the firewall on an XT6? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 14 Share Posted June 14 What’s the reason for moving the throttle cable and changing pedals? Cheers Bennie Quote Link to comment Share on other sites More sharing options...
linkthehero1234 Posted June 30 Author Share Posted June 30 On 6/14/2024 at 4:22 AM, el_freddo said: What’s the reason for moving the throttle cable and changing pedals? Cheers Bennie Sorry for the late reply, I'm putting an STi 6 speed into the car (which was originally automatic) and converting to a hydraulic clutch, so I need to change the pedals so they can work with the hydraulic clutch and move the throttle cable (if necessary, I might be able to go without moving it) so it doesn't interfere with where the clutch master cylinder mounts to the pedal box Quote Link to comment Share on other sites More sharing options...
