ShopDad Posted June 20 Share Posted June 20 When EJ22's and EJ25's were available in the same year, did they use the same transmissions? Different gear ratios maybe? Thanks for any insight you can give me. Greg Quote Link to comment Share on other sites More sharing options...
ocei77 Posted June 20 Share Posted June 20 check cars101.com O. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 20 Share Posted June 20 (edited) 2 hours ago, ShopDad said: When EJ22's and EJ25's were available in the same year, did they use the same transmissions? Different gear ratios maybe? Thanks for any insight you can give me. Greg yes. Final drive ratios differ but they’re interchangeable. Match the rear diff, drive in FWD or otherwise address the final drive ratio and swap away. also 99 is an odd cross over year of Phase I and II. 956-98 stuff is easy and simple. 99 can still interchange but there can be quite a variety. Edited June 20 by idosubaru Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 20 Share Posted June 20 If a manual gearbox you can’t drive it in FWD. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 20 Share Posted June 20 14 hours ago, el_freddo said: If a manual gearbox you can’t drive it in FWD. True I am assuming a lot in this very vague request. Although a failed VLSD can be used to convert an MT Subaru to FWD or RWD. Lol Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 21 Share Posted June 21 23 hours ago, idosubaru said: True I am assuming a lot in this very vague request. Although a failed VLSD can be used to convert an MT Subaru to FWD or RWD. Lol Yes, very vague. Thought adding the manuals can’t be driven in front wheel drive would have all bases covered Cheers Bennie Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 22 Share Posted June 22 3 hours ago, el_freddo said: Yes, very vague. Thought adding the manuals can’t be driven in front wheel drive would have all bases covered Cheers Bennie Yes sir, thanks, that makes the most sense to clear that up. Quote Link to comment Share on other sites More sharing options...
