quiggs Posted June 24 Share Posted June 24 (edited) 1993 Legacy Sedan 5MT. Suddenly car won’t move. Engine runs fine, shifter goes into gear. Obvious first guess is clutch (not hydraulic), but that was replaced just 10K miles ago, and had no prior signs of trouble. I would welcome any alternative (hopefully cheaper) explanations. (Side note: This happened after theft recovery and tow; the tow was on a flat-bed. Maybe thief didn't know how to drive a stick?) Edited June 24 by quiggs more detail Quote Link to comment Share on other sites More sharing options...
88SubGL Posted June 24 Share Posted June 24 I assume that if it’s not hydraulic, it’s a cable. Could the cable be broken? Look at where it attaches to the to the clutch fork, have someone press the clutch pedal and see if the fork moves. Quote Link to comment Share on other sites More sharing options...
quiggs Posted June 24 Author Share Posted June 24 44 minutes ago, 88SubGL said: I assume that if it’s not hydraulic, it’s a cable. Could the cable be broken? Look at where it attaches to the to the clutch fork, have someone press the clutch pedal and see if the fork moves. It the cable were broken, then wouldn't the clutch be stuck in engaged mode rather than disengaged mode? Quote Link to comment Share on other sites More sharing options...
nvu Posted June 25 Share Posted June 25 Check if the rear axles popped off. The rear axles could pop off from the diff but visibly look normal. Yank on them to find out. The pedal would be very soft and stick to the floor if the cable was broken. Quote Link to comment Share on other sites More sharing options...
quiggs Posted June 25 Author Share Posted June 25 58 minutes ago, nvu said: Check if the rear axles popped off. The rear axles could pop off from the diff but visibly look normal. But even if that happened, wouldn't the front wheels still have power? Quote Link to comment Share on other sites More sharing options...
nvu Posted June 25 Share Posted June 25 It would, maybe for 5 miles before the center diff breaks. That's the only easy thing left to check. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 25 Share Posted June 25 11 hours ago, quiggs said: But even if that happened, wouldn't the front wheels still have power? Nope. Well, at least not easily. It would be super slow at best. 2nd/3rd/4th gears work? Or do they at least try to move the car once the clutch is actuated? The thief may have completely stripped 1st gear. Drain the oil and see what comes out with it. If it happens to be dual range like we have over here, it could be in neutral between low and high range. But I doubt you’ve got a dual range gearbox in your EJ Subi stateside… Cheers Bennie Quote Link to comment Share on other sites More sharing options...
quiggs Posted June 25 Author Share Posted June 25 1 hour ago, el_freddo said: 2nd/3rd/4th gears work? Or do they at least try to move the car once the clutch is actuated? No gears work - not even the smallest nudge. The feeling in my hand on the gear shift knob is that I've gotten it into the gear, but I guess I can't even be sure of that. Also the action of the clutch pedal feels normal (in terms of travel and resistance). Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 26 Share Posted June 26 Remove the starter motor hand have a look at the clutch pressure plate for signs of damage. Im guessing there’s no noises when gear is selected and the clutch released? Also not asked yet, what brand of clutch was put in 10,000 miles ago? It’s certainly an odd one! Cheers Bennie Quote Link to comment Share on other sites More sharing options...
