sandmtnjeep Posted July 18 Share Posted July 18 I'm trying to find out the proper operation sequence for the cooling fans on a 2006 Baja turbo. My primary motor went out and I replaced it and now both fans run with the air conditioner on. I don't remember if that is the way it worked before. Just trying to find out the correct operation pattern . Any insight appreciated. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 19 Share Posted July 19 Both fans should run with the AC on. I believe this operation should be at the slower “quiet” speed. There should be a faster speed for times when the engine is hot/working hard with or without AC on. There may be times that only the primary fan operates but I’m unsure of this. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
sandmtnjeep Posted July 20 Author Share Posted July 20 Thanks for the information. Quote Link to comment Share on other sites More sharing options...
nvu Posted July 20 Share Posted July 20 If you want to test the new fans, there's two green connectors under the driver side dash. When you connect them together, it throws the car into test mode. It cycles all the relays on and off. You should see the fans go from off, fast, slow. If you see only fast, it's probably a non-oem fan. Unplug the green connectors when you're done. Quote Link to comment Share on other sites More sharing options...
