Ravenwoods Posted July 21, 2024 Share Posted July 21, 2024 This car has an AT and about 220,000 miles on it. When I look under the front of the car it leaks from the front pretty much center of the engine. Revving the engine speeds up the leak dramatically. I haven't had time to examine it closely up on blocks yet. Leaks about a quart of oil in 20 miles or less. I don't see anything on top of the engine leaking, so probably from under the timing belt cover. Any suggestions on the likely culprit? Can I fix it without taking the engine out? Link to comment Share on other sites More sharing options...
el_freddo Posted July 21, 2024 Share Posted July 21, 2024 Probably a front crank seal. That’s my guess. This happened on my brumby once. That was a fun drive home hoping I didn’t starve it if oil! Cheers Bennie Link to comment Share on other sites More sharing options...
89Ru Posted July 21, 2024 Share Posted July 21, 2024 crank seal doesn't require engine removal. just follow steps for timing belt change. while you're down there consider pulleys, water pump, belt, etc. dealer only seals, japanese pulleys, aisen water pump, and mitsuboshi belt. good tbelt kits on ebay. Link to comment Share on other sites More sharing options...
lmdew Posted July 22, 2024 Share Posted July 22, 2024 While you are in there tighten the oil pump back plate screws and replace the o-ring. 2 Link to comment Share on other sites More sharing options...
Rooster2 Posted August 24, 2024 Share Posted August 24, 2024 Had same problem with my 99 Outback years back. My crank seal went bad, creating a massive oil leak. Had seal replaced by a friend. He didn't charge much, so must be a fairly easy repair. Link to comment Share on other sites More sharing options...
