DaveD Posted August 13 Share Posted August 13 Hi All, We have a 2009 Impreza Sport (base). The steering wheel starts shaking when accelerating to about 70 km/h. When I reach speeds of 70km+ and accelerate faster there is no shaking. However, when I take my foot off the gas, the steering wheel starts shaking again. So short accelerated no shaking, deceleration at high speeds causes shaking. Tires are the same size, balanced and rotated. The brake calipers move in and out freely. New rotors and pads. What else should I be checking and how do I check them? Could it be lower ball joints? CV axle? Tie rod ends? And what should I check first (most likely cause)? Any advice is appreciated. Dave Quote Link to comment Share on other sites More sharing options...
forester2002s Posted August 13 Share Posted August 13 (edited) Could be a CV-joint, especially if the vibration seems to be from one wheel only. And more likely a front CV-joint, as you say that the steering wheel shakes. Or could be the universal-joint and/or support-bearing on the rear drive-shaft. Edited August 13 by forester2002s Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 14 Share Posted August 14 Check your ball joints. Quote Link to comment Share on other sites More sharing options...
brus brother Posted August 16 Share Posted August 16 drive shaft U joint? Quote Link to comment Share on other sites More sharing options...
