GunnyLaylaGL Posted August 28, 2024 Share Posted August 28, 2024 I recently burned a main fusable link. After repairing it my battery light would stay on after turning the ignition off and the fuel pump would continue to run. I replaced the voltage regulator and inspected the feul pump relay for damage but cannot locate a replacement. Any insights would be appreciated Link to comment Share on other sites More sharing options...
Steptoe's photos Posted August 29, 2024 Share Posted August 29, 2024 (edited) i first ask what were you doing to burn out a FL in the first place, because it seems something may have fused together across a circuit or a switch somewhere. Does your battery have a drain on it overnight and go flat on you ? And just what did you do to repair/replace the burnt out FL ? Edited August 29, 2024 by Steptoe's photos Link to comment Share on other sites More sharing options...
