2002 Subaru Impreza TS - AC Compressor 2002-2003 Only?
Very unlike Subaru to have such a limited part: 2002 Subaru Impreza TS - AC Compressor 2002-2003 Only is what the yards and Car-part.com are listing.
Subaru Parts shows a little more of a year range 2002 - 2007 but it's hard to tell in the yards.
Looking for a good AC Compressor.
Thanks,
Larry
2003-07 impreza should be a safe bet, but other models are the same in the era should work too.  It's been a while, I forgot which year compressor I swapped in to replace the 2002 impreza wrx.  The electrical connector was different.  My 03 had a 1 pin connector.  It's 12v to activate the clutch.  Cut the connector from the old clutch and put it on the newer unit.  Been working fine since 2015
  • Thanks 1
  • 4 weeks later...
Replace the compressor and evaporator coil with good used from Colorado.  New Condenser.  The old condenser was restricted just blowing through it.
Serviced today and it's working great!
