saltytheseadog Posted December 15 Share Posted December 15 I'm resurrecting a Loyale that hasn't been on the road for awhile and both turn signal indicators don't work. All the turn signal lights and the hazard flashers are working. I'm wondering how to access the bulbs or the wiring as I suspect the ground may be faulty as both lights have failed and they share a common ground. Link to comment Share on other sites More sharing options...
moosens Posted December 15 Share Posted December 15 Might be tricky to reach. I can’t recall since it’s been quite a while since I’ve owned that era Subaru. But I do know the lamp sockets twist 10 degrees or so and then pull away. Yes, grounds are a key when these cars get older. Be sure that ground is solid, clean, and there’s plenty of healthy metal around that general area or you’ll not have a big enough field to support a ground. If that’s the case run that ground to a more solid metal area. Link to comment Share on other sites More sharing options...
88SubGL Posted December 16 Share Posted December 16 So your 4 ways flash but your turn signals, the lights come on but don’t flash? If that’s what’s happening, I would suggest taking the 4 way flasher unit and swapping it with the regular turn signal flasher and see if it works. It won’t cost you anything if doesn’t make a difference. Link to comment Share on other sites More sharing options...
saltytheseadog Posted Thursday at 09:07 PM Author Share Posted Thursday at 09:07 PM 88SubGL read the OP So I pulled the Brain box down for a look see and there doesn't look like there is any access to the rear of the dash console short of removing the steering column and a whole bunch of other stuff. Is there any other way in other than cutting a hole in the top of the dash. Link to comment Share on other sites More sharing options...
88SubGL Posted Friday at 09:27 PM Share Posted Friday at 09:27 PM I did read it and it was not clear. Maybe adding the words dash or instrument panel would have made it clearer. Link to comment Share on other sites More sharing options...
