I got tired at page 18...
Well, it's been forever since I've posted, but I have some questions.
- What is a good bolt up turbo for the money for a 88 Turbo Wagon?
- Can I use a XT pressure plate and disk/throwout/pilot?
- What's the Accel part # for the Super Stock Coil?
- What kind of intakes are you running?
- What's the general consensis on intercoolers? What works best?
- Would a 3in turbo back be to big?
- How about cross drilled/slotted rotors in front?
- How much boost can we run before fuel cut?
Heres a link on Turbo's...
Turbo types
The XT6 flywheel is what you want, I believe.
Dont bother with Accel, to many going bad. MSD is a good choice.
Spider intake from a XT (Some have them, some dont. One from a turbo is prefered.
A IC from a WRX works great with the spider intake.
3in might be a little big, 2 3/4 might work better.
You want drilled discs? Go for it$$$
Not sure on the fuel cut to boost ratio. You can have fuel cutout with normal boost, sometimes.
Hope this helps.
i am currently trying to get a tdo4 turbo from a wrx on my rx, i am using the wrx intercooler and downpipe , i have a 3" cat back for it aka the "ghettoback". i am getting a custom header made for the set up. i just need to get a new ignition coil, new fuel pump, and maybe some injectors.
TD04, VF10, VF11....etc...
Its the same thing. Use an XT6, as it can hold more power.
I would not recommend these any more...as many of the newer ones are starting to crap out, and mine seems to be inconsistant nowadays...
Ive got the basic 3 inch ID "typical rice-boy" cone on a MAF adapter plate bolted to the air flow meter/MAF.
For the best in directness and staying with SUBARU stuff...a WRX/STi/Legacy TMIC works best...the WRX ones can be had on ebay for CHEAP.
Too small. :banana: Anything from 2.5 to 3.5 should be fine.
Do not go drilled. I can get CarboTech slotted rotors.
depends on year...anything from 85+ will be 9psi. The 85-86 flapper style (pre-MAF) has an overboost switch which can be unplugged, therefor allowing infinate boost. the MAF cars are stuck at 9 PSI until you find some electronic way around it. Ofcourse, with a TD04 or larger and IC and full exhaust mods...you should not need more than 8.5 psi.
I can get you a TWE header and downpipe too...the header will bolt any IHI turbo, and the TD0x series (13G, 16G and 20G). The DP only fits the VF7, but there are plenty of aftermarket ones avalible for the new style 5 bolt turbos.
See this thread:
http://www.ultimatesubaru.org/forum/showthread.php?t=19658&highlight=performance+dealer
And this one:
http://www.ultimatesubaru.org/forum/showthread.php?t=19634
Also, these as well:
http://www.ultimatesubaru.org/forum/showthread.php?t=19813
http://www.ultimatesubaru.org/forum/showthread.php?t=19817
http://www.ultimatesubaru.org/forum/showthread.php?t=19816
thanks for looking!
Back pressure after the turbo must be as low as possible. Its up to the cams, header and everything else infront of the turbo to make you move when you want to move. Making the TBE smaller only increases spool, backpressure, and decreses high end performance.
Turbo exhaust characteristics are not the same as NA.
i have an 88 turbo wagon, and i have my turbo manualy regualted at 11PSI and i have never hit fuel cut, untill i opened the intake up to a 2.5 inch pipe into the throtle body, went back to a 1.5 inch, no more fuel cut.
-=suberdave=-
There are exceptions to the rule i posted...its *SUPPOSED* to hit fuel cut....the two RX's i have now never hit fuel cut, and I ran them around 16-18 PSI at times. Mostly they stayed around 14.
The other RX, Pleiades current one, will hit it ocassionally...but its not a regular cutter.
i know you need atleast some backpressure or you wont get a consistant power flow, or something like that.
The turbo's exhaust turbine provides all the backpressure that the system needs.
