Nunyabis12 Posted January 22 Share Posted January 22 Is there an easy way to adjust it or do I just have to sit on a hill and play it by feel? Link to comment Share on other sites More sharing options...
88SubGL Posted January 22 Share Posted January 22 What’s it doing or not doing? Link to comment Share on other sites More sharing options...
Nunyabis12 Posted January 22 Author Share Posted January 22 4 hours ago, 88SubGL said: What’s it doing or not doing? The cable is just completely loose and almost detached because the guy who owned it before me was too lazy to put in the effort Link to comment Share on other sites More sharing options...
moosens Posted January 22 Share Posted January 22 At the hill holder unit is there a stubby thick wire spring on the lever that cable would pull ? Maybe he took the spring off and didn’t really secure the lever and that lever has worked its way back? Link to comment Share on other sites More sharing options...
Nunyabis12 Posted January 23 Author Share Posted January 23 1 hour ago, moosens said: At the hill holder unit is there a stubby thick wire spring on the lever that cable would pull ? Maybe he took the spring off and didn’t really secure the lever and that lever has worked its way back? The spring is still on and the lever actuates brakes still, the cable on the clutch fork is just completely loosened though Link to comment Share on other sites More sharing options...
moosens Posted January 23 Share Posted January 23 Set the clutch and allow 1/8” play to the hill holder engagement is how I recall that adjustment. But it’s been about a decade since I’ve owned one. If nobody else chimes in I’ll look it up in the manual. Or did you lose the nuts at the threaded end? 1 Link to comment Share on other sites More sharing options...
Nunyabis12 Posted January 23 Author Share Posted January 23 1 hour ago, moosens said: Set the clutch and allow 1/8” play to the hill holder engagement is how I recall that adjustment. But it’s been about a decade since I’ve owned one. If nobody else chimes in I’ll look it up in the manual. Or did you lose the nuts at the threaded end? No I was just wondering if anyone knew how to adjust it properly because I assumed doing it on a hill is the wrong way Link to comment Share on other sites More sharing options...
el_freddo Posted January 24 Share Posted January 24 22 hours ago, Nunyabis12 said: No I was just wondering if anyone knew how to adjust it properly because I assumed doing it on a hill is the wrong way You’d be right in assuming that! As Moosen’s said, allow a bit of play - then test it out, you should have the hill holder let go just as the clutch takes up some bite. You don’t want the clutch to be fighting the hill holder (too tight). Test, adjust, test etc until you’re happy with how it behaves/feels when you use it. Looser is better than tighter - you’ll learn how to drive with how you adjust it. I disabled mine in my L series - had too many sketchy situations when reversing down steep hills I didn’t make it up. I just live without it and don’t really notice any difference really (my brumby didn’t get one so they’re basically the same to drive in that regard). Cheers Bennie 1 Link to comment Share on other sites More sharing options...
Nunyabis12 Posted January 24 Author Share Posted January 24 3 hours ago, el_freddo said: You’d be right in assuming that! As Moosen’s said, allow a bit of play - then test it out, you should have the hill holder let go just as the clutch takes up some bite. You don’t want the clutch to be fighting the hill holder (too tight). Test, adjust, test etc until you’re happy with how it behaves/feels when you use it. Looser is better than tighter - you’ll learn how to drive with how you adjust it. I disabled mine in my L series - had too many sketchy situations when reversing down steep hills I didn’t make it up. I just live without it and don’t really notice any difference really (my brumby didn’t get one so they’re basically the same to drive in that regard). Cheers Bennie One more question and this might be stupid, if I had the hill holder set up correctly would it activate whenever I push the clutch in? Like if I'm on the highway and I try to shift? Link to comment Share on other sites More sharing options...
el_freddo Posted January 24 Share Posted January 24 5 hours ago, Nunyabis12 said: One more question and this might be stupid, if I had the hill holder set up correctly would it activate whenever I push the clutch in? Like if I'm on the highway and I try to shift? No, but you might feel it slightly sometimes when reversing. I believe there’s something in the device that uses gravity to activate the hill holder. If facing down hill it won’t hold the brakes on - and it seems to only act on one part of the system. EG: brakes the front left and rear right or vice versa. Pretty sure it’s the FL and RR circuit that’s used. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
