gazza01 Posted Tuesday at 01:17 AM Share Posted Tuesday at 01:17 AM Is its safe to remove the old Camshaft Gear from Suby EA81 heating it using a Oxy torch, or is there another way, Ive git to replace mine. Link to comment Share on other sites More sharing options...
moosens Posted Tuesday at 03:54 AM Share Posted Tuesday at 03:54 AM I was told you’ve got to split the cases. I didn’t want to hear that too if that helps. Good luck. Post back how it got done please. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted Tuesday at 02:12 PM Share Posted Tuesday at 02:12 PM A "more gentle" option may be an induction heater. If you don't have one yet, I'd recommend saving up for a decent Chinese one ($200 range), they work wonders. That way you're only heating up what you need to and you're not affecting the temper of the steel as much. I've never removed an EA81 cam gear, just my 2¢. Any machine shop worth their salt would tackle that no problem. :] Link to comment Share on other sites More sharing options...
moosens Posted Tuesday at 04:20 PM Share Posted Tuesday at 04:20 PM Please investigate before you decimate. If it’s in the block. Heat and pullers won’t do anything. Link to comment Share on other sites More sharing options...
moosens Posted yesterday at 01:52 AM Share Posted yesterday at 01:52 AM (edited) Sorry I read crank instead of cam. Cam gear on the EA71 is two small bolts. Same on EA81 Edited yesterday at 01:54 AM by moosens Link to comment Share on other sites More sharing options...
