Differences between models
Hi!
I have seen many Subaru Loyales on the internet.
What is the difference between the Loyale und the Leone?
There are 2 different types of the Leone in Austria:
The DL, wich has no high roof, no headrests in the backseats, no rev counter, no electric windows and more plastic inside
The GL has this high roof, all electric inside, and more velour
Is this similar to the US-models?
Greetings
Lukas
We have the DL, GL and GL-10
Then after 1989, they became the Loyale
The GL came with the high roof as an option, but there aren't a lot of them in the US
A large number of the GL-10s were turbocharged
DL is bottom of the line.
There was so much mixing and matching of parts done that its just crazy. Just the subject of what a GL-10 came equipped with has generated a number of multipage discussions in the past year.
This is going to get very long and confusing If we compare the whole USDM L- line to the EDM L- line..
the high roof model you mention is called the Touring Wagon here in the us. the ones with more velour are the gl-10 models, they have the velour seats and door panels, and also the trip computer and a digital instrument cluster
in the us, subarus were called DL, GL, and STD from 80-98. in 1990, subaru came out with the legacy. so since there was a new line with a name, the dl/gl from 90-94 were called the loyale
in the us, the gl-loyake models have the composite single piece headlight with the replaceable halogen bulb. the DL models have the standard 4 headlight system using sealed beam headlights
mechanicaly the cars are the same, in the us and overseas, from body panels to interior options to the motor and driveline.
GD the Leone name was from the 70's through till the Liberty (Legacy) and Impreza took over for the guys overseas heck I find it funny that companies like Jeep called their liberty over here a liberty and then call it the cherokee over in europe and various other places instead of just gettin rid of the cherokee here and replacing it with the liberty and calling it the cherokee over here also but still it's funny
No - he's talking about the difference between an EA81 and an EA82 to us. Subaru refers to the whole EA82 line ('85-'94) as the "Loyale". The Leone is the '80-'84 EA81 body. Completely different cars.
Hmmm... No. Sorry dude you swung way wide on that one.
Reread the original post. Its clear he's referring to trim lines within a single body style.
European market L-series cars are NOT referred to as a Loyale, even by subaru.
Hi Guys!
I was talking about the socalles EA82 models.
To summ it up a little:
The Leones 1985 until 1989 were available as DL, GL and STD
The Loyale was available only from 1989 until 1994 without the high roof
This modelline is called EA82.
In Austria, the Leone was available from 1985 until 1991. From 1985 until 1987
there was a 1600DL - model, wich was very naked inside and with the old engine from the EA81. Also from 1985 until 1989 the 1800 was available as DL, GL and GLT (Turbo). The GL and GLT had the high roof and more velours. And from 1989 until 1991 only the socalled Leone Ranger DL was available. This
model had no velours, no high roof and was more rustproof then the models
before 1989.
The EA81 was calles 1600/1800 in Austria, only the EA82 1985-1991 was called Leone.
Greetings and thank you
Lukas
