5 lugs conversion
Well I don't know of any car the stirs a caldron, but if you want to know which car(s) to get the pieces from, I'll tell you. For the rear pieces, you have only one choice, and that is a XT6 AWD, from that you need the backing plate, the hub (the piece that bolts to the axle) and the rotor, the rear caliper is the same as any rear disc EA82. Up front you have some choices for some of the parts, but some must come from a XT6 (either FWD or AWD), you need the lower suspension arm and the ball joint, you'll need the tie rod ends, and you'll need the front calipers. You can get the following parts from a XT6, a Legacy, or an Impreza, the front strut complete, the front rotors, the front backing plates, the front knuckle, and the axles. The Legacy axles may be too long, so I would stay with either the XT6 or the Impreza. Here is a link to my web sitye that shows my first conversion, it should help a little, http://corkysrocks.net/Conversion%204%20to%205.htm .
  • 3 weeks later...
