NHBill Posted August 15, 2004 Share Posted August 15, 2004 I'm new to the USMB. This is great! Any recommendations for a Subaru mechanic in the Concord, NH area? Link to comment Share on other sites More sharing options...
silversoobiegirl Posted August 16, 2004 Share Posted August 16, 2004 NHBill said: I'm new to the USMB. This is great! Any recommendations for a Subaru mechanic in the Concord, NH area? I'm new too, but I think there's a Subaru dealer in Concord -- Ed Reilly Subaru. I don't know anything about them though :-\ If you want to take a ride to Milford (south of you), I've taken my Subie there and they seem pretty knowledgeable. They'll even take coupons that have other Subaru dealer's names on them, as long as the coupons originated from SOA. Hope I've helped, my friends had luck at Exeter Subaru, too. Link to comment Share on other sites More sharing options...
shortlid Posted August 17, 2004 Share Posted August 17, 2004 Hey I live in Nashua guys just moved here two weeks ago!! I also need a good independant Subaru mech. in the area. Lets look around the area together then post! Link to comment Share on other sites More sharing options...
shortlid Posted August 17, 2004 Share Posted August 17, 2004 I found a shop specilizing in import cars in Hudson on Route 111. The owner has a few Subaru's on the lot and says he has repaired a lot of them. Place is called Roy's. Joel Link to comment Share on other sites More sharing options...
Ranger83 Posted August 17, 2004 Share Posted August 17, 2004 I posted a message here weeks ago for Manchester, NH with no response. Took a look at the Mechan-X files on cartalk.com and there were a number of well-recommended garages. I can't imagine there are many garages in New England that haven't worked on plenty of Subrarus. http://www.cartalk.com/content/mechx/ Link to comment Share on other sites More sharing options...
NHBill Posted August 24, 2004 Author Share Posted August 24, 2004 I'm using a small shop called Auto Advantage in Concord, NH. A BMW and Euro car specialist who happens to be an 8 year veteran of a Subaru service department in Virginia. My 97 Legacy Outback (144K Miles) is new to me, and with a 2.5 L engine I thought it had head gasket problems simply because there was grease inside the coolant overflow reservoir. He has tested it for combustion gases and found no problems, but I need to throw money into the timing belt change and rollers for same, plus oil pump seals. I will report to the USMB my experience there. Link to comment Share on other sites More sharing options...
shortlid Posted August 24, 2004 Share Posted August 24, 2004 Thanks! could you ask him if he has ever done a Legacy heater core?? Joel NHBill said: I'm using a small shop called Auto Advantage in Concord, NH. A BMW and Euro car specialist who happens to be an 8 year veteran of a Subaru service department in Virginia. My 97 Legacy Outback (144K Miles) is new to me, and with a 2.5 L engine I thought it had head gasket problems simply because there was grease inside the coolant overflow reservoir. He has tested it for combustion gases and found no problems, but I need to throw money into the timing belt change and rollers for same, plus oil pump seals. I will report to the USMB my experience there. Link to comment Share on other sites More sharing options...
