Markus Posted August 16, 2004 Share Posted August 16, 2004 This issue is related to a short previous thread regarding the 10A "Meter" fuse that cripples the car. When it blows the instrument cluster stops working along with the power windows and sunroof AND the automatic quits shifting. This bears out looking at the schematics, Fuse 15 (Meter) is used to supply power to all those items in some way. Well finally I hit the point where I popped about 8 fuses (in a row) and concluded that I had a problem.....before I would replace the fuse and run with out a problem for days. Using a meter I have a dead short to the point that my positive battery terminal has continuity with the ground lug on the engine. Out of desparation, while I was stranded, I tried progressively higher fuse values (dumb I know but I was stuck). Each one would pop a little later (milliseconds) and at 25 A I started to smell (a little) smoke - then the fuse went (I stopped the experiment). The smoke seemed to be coming from the roof (sunroof?). It seems every time that I had the problem the sunroof was open, to the best of my memory. 1) Has anyone troubleshot this type of problem and have hints of the best ways to go about it? I'm an electrical engineer but its much easier to look at the back of an industrial control enclosure. 2) How do I remove the head liner to get to the sunroof, where are the screws? 3) Anyone disconnect the sunroof relay? I can see the sucker (pink, Haynes calls it red) with the knee panel removed and can get my hand on it when laying on my back and twisting my arm like a pretzel but can't seem to disconnect it. If I can get this off then I may be able to avoid remoing the headliner if not needed. As always, any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
HobbyWrench Posted October 22, 2010 Share Posted October 22, 2010 Hi Markus, Did you ever figure this out? Coincidentally, I also have a '90 LS Wagon FWD, AT, NA and the exact problem has just surfaced - continuously blowing out Fuse 15. Thanks, Mike Link to comment Share on other sites More sharing options...
bstone Posted October 22, 2010 Share Posted October 22, 2010 Holy ancient threads, Batman! Link to comment Share on other sites More sharing options...
johnceggleston Posted October 22, 2010 Share Posted October 22, 2010 markus has not logged on since august '04. Link to comment Share on other sites More sharing options...
