sandman Posted August 16, 2004 Share Posted August 16, 2004 It overheated for some reason (oil and water were fine) that I have not investigated yet. But looking at the oil out the exaust the really bad blowby and the knocking and no oil pressure, I say its dead. So what can I swap into it? Can I use a non turbo motor and swap my turbo stuff onto it? I know the compression is higher so knocking would be a concern. I could fight that with good gas and timing. Do I need the same thing or are there other options? Sorry for the newb questions but I do not have too much experience with Subaru's. I do know that I want to keep the car. Its too much fun too drive. Its a '87 GL10 Wagon, Turbo, 4 wheel drive, manual. Thanks. Link to comment Share on other sites More sharing options...
WJM Posted August 16, 2004 Share Posted August 16, 2004 if you drive the F out of it like i did...you will get about 24k miles out of a 9.5:1 turbo set up like I did. Otherwise...93 gas and about 15 deg of timing will get you close to 30 MPGs with a MT, and driving it "normally" Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 16, 2004 Share Posted August 16, 2004 You could try using a carb block, which is between the two extremes. Turbo is 7.7, carb is 8.5, and SPFI is 9.5.... GD Link to comment Share on other sites More sharing options...
sandman Posted August 16, 2004 Author Share Posted August 16, 2004 Theres a carb engine in the yard here I believe in the same year of car. Do you just have to change the intakes over or is there more to it? Thanks for the info. I see nothing wrong with more compression. Link to comment Share on other sites More sharing options...
JWX Posted August 16, 2004 Share Posted August 16, 2004 you've got to change the heads out. Link to comment Share on other sites More sharing options...
bushbasher Posted August 16, 2004 Share Posted August 16, 2004 be sure to check for cracks going into the ports, cause you overheated it. Link to comment Share on other sites More sharing options...
calebz Posted August 16, 2004 Share Posted August 16, 2004 Theres a carb engine in the yard here I believe in the same year of car. Do you just have to change the intakes over or is there more to it? Thanks for the info. I see nothing wrong with more compression. YOu have to change pretty much everything except the T-belt tensioners and the oil pump. But if you have it torn down that far, you should replace/rebuild them anyway. I am in the iddle of doing this exact thing right now.. just stripped the carb block last night and will be cleaning and prepping for reassembly tonight Miles Fox has also done this with apparent success Link to comment Share on other sites More sharing options...
archemitis Posted August 17, 2004 Share Posted August 17, 2004 one thing that always made me nervous about using a junkyard carb motor, is that they usually run fat, all the time, which washes the walls of oil, and CAN make the rings last... less long. what about the na mpfi, i think that block is the same as carb compression, right? Link to comment Share on other sites More sharing options...
baccaruda Posted August 17, 2004 Share Posted August 17, 2004 the easiest thing to throw in there (besides another turbo engine) would be a N/A MPFI engine as I believe the wiring and computer are the same. you might keep an eye out for one of those... Link to comment Share on other sites More sharing options...
