LUVMYBRAT Posted August 17, 2004 Share Posted August 17, 2004 My kids turbo cp is starting to aquire several exhaust leaks, one most notably on the down pipe before turbo. So I'm planning on fixing this but with performance in mind what should be done? larger dia. pipe? I'm thinkin no cat for sure! how about the piece from head to turbo, I'm not totally up on the turbo thing so I need some sound advise. Link to comment Share on other sites More sharing options...
mattyg41383 Posted August 17, 2004 Share Posted August 17, 2004 If Wyoming has emissions laws, you'll need to put a cat on there. Generally speaking, with a turbo car you want a large diameter exhaust, back pressure really isnt needed. On my drag XT, I made a downpipe out of 3" pipe from a truck exhaust, and run that DP right into a drag muffler. Opening up the exhaust also makes the car sound great. Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted August 17, 2004 Author Share Posted August 17, 2004 so what is the pipe between the head and turbo called and what can be done to boost oerformance there? Link to comment Share on other sites More sharing options...
nutt7 Posted August 17, 2004 Share Posted August 17, 2004 the up pipe. changing the diameter of this pipe may not be necessary or effective (not 100% sure) what will help is to make the two pipes enter into a collector evenly as opposed to the way it tis now, where the passenger side exhaust enters the pipe perpendicular, thus disrupting flow and probably causing turbulence. mandrel bends are always good too. making the pipes equal length to the collector will probably help too. if you have the cash, get in on that TWE order in here. as for the down pipe, 2.5 in will probably be plenty and if a cat must be used, place it down stream a bit. Link to comment Share on other sites More sharing options...
86subaru Posted August 17, 2004 Share Posted August 17, 2004 here in this part of ohio we do not have emission laws, i left the pipe on from the motor and i call it a big foot ball and had it cleaned out but left the shell on , and 2in pipe all the way back and a turbo muffler , it will make the motor run cooler and more hp but alittle tint sound not bad , ngk plugs, 8mm wires, acell coil, k-n filter Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted August 17, 2004 Author Share Posted August 17, 2004 I seen the TWE thing how much for the up-pipe? Link to comment Share on other sites More sharing options...
nutt7 Posted August 17, 2004 Share Posted August 17, 2004 they just posted prices on the first post...about $400 for UP and $185 for DP Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted August 17, 2004 Author Share Posted August 17, 2004 yea I just got done reading the post. Way more than I can afford, I only paid 400.00 for the car. Link to comment Share on other sites More sharing options...
86subaru Posted August 17, 2004 Share Posted August 17, 2004 cleaned out , 2 in pipe, turbo muffler, 100 total included labor Link to comment Share on other sites More sharing options...
86subaru Posted August 17, 2004 Share Posted August 17, 2004 but of course that price is here in this part of ohio and only 1 place that i know of Link to comment Share on other sites More sharing options...
