bump
this is a wild guess, but if the mirror is on the door, wouldn't pulling the door panel expose the wiring and mounting hardware to the mirror?
Start by removing the small panel on the inside of the door opposite the mirror. There should be a couple of 10mm bolts that hold the mirror on. Track the wire which will have a harness to release. If the wire goes behind the door panel, you will need to remove it to detach/attach the new wire. This is a VERY easy operation. The hardest part (which is not very hard) is to remove/install the door panel if necessary. Give a shout if you have any problems.
