Anyone know what the lug nut torque specification is for;:confused:
01 Forester?
82 GL?
I did a search but didn't find much.
What's the preferred pattern for tightning 4 lug, 5 lug and 6 lug?
Thanks,
Glenn
Proud New owner of Harbor Freight Torque Wrench. :brow:
I tighten them one half then one quarter turn past snug. THey dont need to be SUPER tight. I used to put them on really tight and ended up breaking 2 studs on a Buick the next time I went to take them off. Are the actual ft/lbs in the owners manual; they usually have stuff like that.
Just like a most anything I use opposite / opposing corners. For example top left, lower right, top right, lower left.
72ft/lbs torque
on my 95, 99, 2001 and 2003
torque them all the same...
use a torque wrench
dont over or under torque as that could lead to issues
under = loose wheel = stripped studs
over = stuck wheel = stripped studs
not fun been there, done that...
Jamie
Do you have alloy's or steelies on the forester (i'm not sure if it matters or not).
I torque the alloys on my outback to ~68 ft-lb's. I believe the appropriate range is 65-72. For the pattern (5-lug), I start with one and then move accross the hub like you would draw a 5-point star. I do this in two or three stages, snug 'em up first, then tighten to about 45 ft-lbs, then 68. I've also found it better to torque them with the wheel off the ground, or just barely touch for the final tightening.
I put a dab of anti-sieze on there too, esp. for steel wheels.
Cool! Nick is as meticulous as I am! I run them up in four stages, star pattern, wheels off until the final tightening - can't hold them by hand.
The difference in running them straight up is apparrent at high speeds, expecially at the second "harmonic" around 100mph.
