ronnie johhhnnn Posted August 23, 2004 Share Posted August 23, 2004 Has anyone ever done this? If not, Do you think it's possible? What are all the parts i would need to get it working? The front end is quite apart right now do to an accident so I figure if im gonna try, I should do it now. Link to comment Share on other sites More sharing options...
nutt7 Posted August 23, 2004 Share Posted August 23, 2004 I dont know what it takes, but I have a condenser and the lines in the engine bay if you decide to go through with this. Link to comment Share on other sites More sharing options...
hush777 Posted August 23, 2004 Share Posted August 23, 2004 I don't know if it would be financialy reasonable if you were to try to go to an R12 system. But if you were to go to a r134 or equivilent system you could do it. I have some of the parts that you would need and also a sheet that was in an 86 sedan (should be the same) for the dealer to follow to install air conditioning in a car after it has left the factory. You would need a condenser, the fluid lines with the proper o-rings for the refridgerant you are using (r12, r134, etc...), the compressor, with the bracket to hold the compressor, receiver/dryer, different alternator pulley (2 groove), pulser assembly, and bracket, the idle control (ficd actuator) unless it is auto-trans and spfi, the a/c relay, the a/c button for the dash and then the evaporator and the wiring diagram, pulse amplifier. Seems like a lot a know but now would be the time to get it done. I don't need this sheet and you can have it, if you would like. I can't help with all of the part as this one was hit in the front with a deer, and the compressor would be to heavy to ship. Took all the rest out. You would have to find the lines, and would be best to get a new receiver/dryer, as they grab moisture pretty quick. Let me know if you want this sheet, even just to look at, and see what all needs to happen. pm or email Hush Link to comment Share on other sites More sharing options...
Karl Posted August 23, 2004 Share Posted August 23, 2004 could you scan that sheet and post it? I too have an 87 non a/c that I was considering putting the A/C into. Mine already has the button on the dash, so I'm one part down! thanks! Link to comment Share on other sites More sharing options...
hush777 Posted August 26, 2004 Share Posted August 26, 2004 I'll have to see if I can get my camera to co-operate in taking pictures of it.....Don't have access to a scanner at the house. If that doesn't work I'll have to get it scanned. But that wouldn't happen till maybe next weekend not this one. Hush Link to comment Share on other sites More sharing options...
hush777 Posted August 30, 2004 Share Posted August 30, 2004 I'm gonna post a picture for you all to take a look at. If the quality is to low and you can't deal with it then I will try to get the sheet scanned this coming weekend. If the quality is ok then let me know and I'll finish posting all the rest of the pictures that I took and type in the instructions... Hush Link to comment Share on other sites More sharing options...
ronnie johhhnnn Posted August 30, 2004 Author Share Posted August 30, 2004 The quality of that picture is good enough. Thank you. I'm interested to see the rest of them so I can decide if I want to go through with it. Link to comment Share on other sites More sharing options...
hush777 Posted August 30, 2004 Share Posted August 30, 2004 Will have to post the rest in sections, but not right now. Been called out on an 8 hour one way run...... won't be back till tomorrow sometime. Hush Link to comment Share on other sites More sharing options...
hush777 Posted September 2, 2004 Share Posted September 2, 2004 Have posted the first side of the sheet as scans on a gallery. Here is the link. Check it. http://www.ultimatesubaru.org/photos/showgallery.php?cat=582&ppuser=&page=1 Hush Link to comment Share on other sites More sharing options...
hush777 Posted September 3, 2004 Share Posted September 3, 2004 For all you people interested in this.... Bump Hush Link to comment Share on other sites More sharing options...
MorganM Posted September 3, 2004 Share Posted September 3, 2004 nutt7 said: I dont know what it takes, but I have a condenser and the lines in the engine bay if you decide to go through with this. And I got the AC pump from my '88 GL wagon if you want it! Link to comment Share on other sites More sharing options...
