Help! Outback won't start unless I shift to "N"
My '99 Legacy Outback LTD 2.5L won't start unless I shift into "N" and even then I may have to shift back and forth from "P" to "N" several times. A buddy thinks there is some sort of safety button or sensor which might be going bad. Any info appreciated!
Let me clarify the problem: Prior to the middle of August, 2004, I could be standing next to the car, reach in with my key, and start the vehicle. Then, I started having to shift from "P" to "N" and then "slam" (not really slam, but forcefully shift) back into "P" for the vehicle to start. Now it won't start in "P" at all, and I have to try several times (while wiggling the shifter around the "N" position) to get the vehicle to start at all. It's like the vehicle doesn't recognize when it's in an appropriate gear in which to start.
The inhibitor/safety/prndl switch is located on the right hand side of the transmission underneath by the transmission oil pan
The connector for it is at the top of the transmission by the firewall
SEA#3
