NoahDL88 Posted August 26, 2004 Share Posted August 26, 2004 whats with the power light on auto legacy's? I drive a MT so i'm not up on my auto's, is it safe to drive? Link to comment Share on other sites More sharing options...
sasquatch Posted August 26, 2004 Share Posted August 26, 2004 It's for when you're feeling "spunky" I may be wrong but without looking it up in my manual the car is supposed to have two different driving modes depending upon the needs you're asking of the car. You can actually switch between modes manually. Have I ever felt a difference? Nope. Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 27, 2004 Author Share Posted August 27, 2004 the light is flashing though, is that a problem? Link to comment Share on other sites More sharing options...
SevenSisters Posted August 27, 2004 Share Posted August 27, 2004 Yes, if it's flashihg you may have a problem. It has nothing to do with two different driving modes. It should come on with the other indicator lights at start up and then go out and stay out. If it comes on and flashes , it's trying to talk to you. Check your manual. Link to comment Share on other sites More sharing options...
Legacy777 Posted August 27, 2004 Share Posted August 27, 2004 When the power light comes on when you floor it, it just means you're driving "less" fuel efficient, and the shift maps will be more agressive. If it blinks it means there's an issue with tranny. You can check the codes by following the instructions on my site. Link to comment Share on other sites More sharing options...
sasquatch Posted August 27, 2004 Share Posted August 27, 2004 SevenSisters said: Yes, if it's flashihg you may have a problem. It has nothing to do with two different driving modes. It should come on with the other indicator lights at start up and then go out and stay out. If it comes on and flashes , it's trying to talk to you. Check your manual. Oh, okay...so it's not different driving "modes" but it's different shift "maps" Link to comment Share on other sites More sharing options...
MiNoahsPinkMartini Posted September 10, 2004 Share Posted September 10, 2004 problem with my tranny?? thats no bueno. It seems to run fine right now. Sometimes it pops on in the morning when i start it and flashes for a second and then stops.. and other times it doesn't.. I'm confused.. but it sounds like my car is confused as well!!! Link to comment Share on other sites More sharing options...
yeah-right Posted September 10, 2004 Share Posted September 10, 2004 A flashing "POWER" light on startup is a indicator that there has been a transmission fault present. However it is unsual that it only does it sometimes - normally it will flash every time the ignition is switched on until the memory is cleared. Go through the proceedure to check & clear the fault code. Then if it does it again then start looking at the fault it gave. Link to comment Share on other sites More sharing options...
