Hi this my first post.I have a 1990 2.2 auto legacy.After reading
some of your post maybe this is common with all autos. It has a breaking
effect from 2 to 3 , under modderate throttle it shifts up faster than you
want, then if you want it to jump back to 2nd you have to plant your
foot, then it down shifts and hunts back and forth between 2nd and 3rd.
Has anybody ever adjusted the bands on this car? Is there anyway to
make this car down shift with less effort?I beleive it has an overdrive
anyway to lock it out? Off the subject a very rough idle on my car
turned up to be a stock timming belt adjuster, it was not even in
contact with the belt. thanks for the help
That's pretty normal in terms of down shifting. You have to dump it in order for it to downshift.
I usually manually shift the gear selector because I want it to downshift, but I don't want it to jump down two gears and have the rpms up around redline.
As for disabling overdrive.....again....just manually shift the gear selector.
