Big Bear Suby Posted August 27, 2004 Share Posted August 27, 2004 I have recently bought dealer springs and had Monroe sensa trac struts put on all four wheels.The rear suspension was at the bumpers before and after the new springs and struts were installed.As far as I can tell the front seems lower as well.I was hoping that the new install would have brought the hieght up some but it seems as if it has lowered the car.Is there something that I could do to raise the hieght up to stock.I am quite confussed on this. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 27, 2004 Share Posted August 27, 2004 Strange - do you have a lot of wieght in the car? Do a search on the board here for "honda springs" - several people have used them in the rear to raise the EA82's beyond stock height.... maybe it will help you out. GD Quote Link to comment Share on other sites More sharing options...
bushbasher Posted August 27, 2004 Share Posted August 27, 2004 maybe they gave you the wrong springs, like rx or xt springs Quote Link to comment Share on other sites More sharing options...
subawoohoo Posted August 27, 2004 Share Posted August 27, 2004 hum wiered, all i can think of is that the origional struts/springs were the 3inch adjustable ones and were cranked all the way up. Hows that sound? all i can think of, unless they were wrong ones. Quote Link to comment Share on other sites More sharing options...
WJM Posted August 28, 2004 Share Posted August 28, 2004 Ive never seen the aftermarket ones being adjustable. You CAN get the XT rear struts, and 4WD fronts....that will raise it about 2 inches front and rear. Quote Link to comment Share on other sites More sharing options...
subawoohoo Posted August 28, 2004 Share Posted August 28, 2004 Ive never seen the aftermarket ones being adjustable. You CAN get the XT rear struts, and 4WD fronts....that will raise it about 2 inches front and rear. Well just a clarification, i meant that the OLD ones were adjustable, and adjusted all the way up, then when he switched in the non adjustable (im assuming), monroe ones, it dropped it. or they're just the wrong ones. dunnno. tyler j Quote Link to comment Share on other sites More sharing options...
calebz Posted August 28, 2004 Share Posted August 28, 2004 probably got sedan struts. they are shorter.. if you want struts that are the same length as the adjustables cranked up, I always order struts for a 90 Loyale 4wd wagon. that seems to be the only way to guarantee that I get the right ones. But you hve to have the long srings to go with it as well. And yes, there are aftermarket adjustables, they are made by KYB. Quote Link to comment Share on other sites More sharing options...
WJM Posted August 28, 2004 Share Posted August 28, 2004 probably got sedan struts. they are shorter.. if you want struts that are the same length as the adjustables cranked up, I always order struts for a 90 Loyale 4wd wagon. that seems to be the only way to guarantee that I get the right ones. But you hve to have the long srings to go with it as well. And yes, there are aftermarket adjustables, they are made by KYB. I was not aware that the 4wd vs 2wd fron wagon springs were different....and that all 4wd struts are the same in aftermarket. TALL. 2wd are short. ive not seen any adjustable KYB's for these things....where can I find them? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted August 28, 2004 Share Posted August 28, 2004 the # for KYB GR2 adjustables (EA82 rear shocks) is 341053 Quote Link to comment Share on other sites More sharing options...
