Cliptin Posted August 31, 2004 Share Posted August 31, 2004 85 MPFI EA82 non-T 3AT Bad idle on at cold start. Once it dies out after the first crank it takes right off just fine. Also, after the car has been pointed downhill (say driving or stopped at a stop sign) it wants to stumble for 10 seconds and then it regains its power. Driving under power downhill does not make the symptom show up but coasting does. Any ideas? I'm also getting really bad gas milage. Link to comment Share on other sites More sharing options...
boing Posted August 31, 2004 Share Posted August 31, 2004 Do you use injector cleaner in your fuel? sounds like injectors that are a bit gummy... by using it, it would also help to displace any water. Not a bad idea to see if there is any water in the fuel filter. boing Link to comment Share on other sites More sharing options...
Cliptin Posted August 31, 2004 Author Share Posted August 31, 2004 Thanks. I've runs about three tanks of premium gas threw her with injector cleaner in the first tank. The car was running and then sat for a week before I bought her and then sat another two weeks while I replaced some parts. thermostat, distributor, cap/rotor/plugs/wires, oil/filter, AT fluid, fuel filter and two hoses, radiator flush Link to comment Share on other sites More sharing options...
