ekimyerac Posted August 31, 2004 Share Posted August 31, 2004 They are working on my road and I put it in 4WD to get in the drive way, now it won't go into 2WD. Goes in to 4WD LO and HIGH. Any ideas. Michael Carey, KD7GHZ 1987 GL Wagon 4WD Link to comment Share on other sites More sharing options...
Svengouli7 Posted August 31, 2004 Share Posted August 31, 2004 Try driving in reverse a few feet Link to comment Share on other sites More sharing options...
northguy Posted August 31, 2004 Share Posted August 31, 2004 Jack up the rear wheel and let it unwind, or find some gravel nearby and shift it there. It's just torque-bound. Link to comment Share on other sites More sharing options...
BobBrumby Posted August 31, 2004 Share Posted August 31, 2004 maybe the nutt has loosened off the 4wd selector that holds it onto the shifter, you will just have to remove the centre dash thing imbertweem the seats to check. i had this happen to me and i thought my handbrake was going on arorund corners oh but then it would be stuck in 4 hi, oh well have a look anyway Link to comment Share on other sites More sharing options...
henrysteele77 Posted August 31, 2004 Share Posted August 31, 2004 I have done this to my hatch, rev it up drop clutch spin wheels = relieves tension on the transaxle, do this while pushing down on shifter, dirt or gravel is best Link to comment Share on other sites More sharing options...
nkx Posted August 31, 2004 Share Posted August 31, 2004 think of the upside! FT4WD for free! Link to comment Share on other sites More sharing options...
northguy Posted August 31, 2004 Share Posted August 31, 2004 If there isn't any gravel nearby, drive up onto the neighbor's fine-trimmed lawn and chirp them off while pushing down on the selector lever. Link to comment Share on other sites More sharing options...
subiemech85 Posted August 31, 2004 Share Posted August 31, 2004 the way I did it was set park brake, shift into reverse, and push down on shifter nothing else worked Link to comment Share on other sites More sharing options...
ekimyerac Posted August 31, 2004 Author Share Posted August 31, 2004 I put the Sub into reverse this morning for about 50 feet and it went into 2WD along the way. Thanks for all the help. Michael Carey, KD7GHZ Link to comment Share on other sites More sharing options...
henrysteele77 Posted August 31, 2004 Share Posted August 31, 2004 thats the easy way out, I like to tear things grass dirt rocks cats what ever acts as lube for the rubber Link to comment Share on other sites More sharing options...
northguy Posted August 31, 2004 Share Posted August 31, 2004 Glad it worked out for you. Link to comment Share on other sites More sharing options...
