August 31, 200421 yr I have a 1995 Impreza 1.8L without a trans dipstick. I bought the car used, and have put about 20,000 miles on it so far. Working at Jiffy Lube, I see Subarus almost every day, but mine is the only one I've ever seen without a dipstick. Because of this, I suspect the fluid has never been changed. At 120,000 miles, this is a bad thing. Any suggestions as to how to change the fluid without a way to fill it? Thanks, Justin Vinall
August 31, 200421 yr I have a 1995 Impreza 1.8L without a trans dipstick. I bought the car used, and have put about 20,000 miles on it so far. Working at Jiffy Lube, I see Subarus almost every day, but mine is the only one I've ever seen without a dipstick. Because of this, I suspect the fluid has never been changed. At 120,000 miles, this is a bad thing. Any suggestions as to how to change the fluid without a way to fill it? Thanks, Justin Vinall Either you're trying to pull our collective leg or you really belong to the Jiffy Lube world . Look again, the dipstick is maybe missing but the opening thru which the trans oil is poured IS there. Just get a used or a new dipstick. You might even steal one from one of your clients and let HIM wonder next time he tries to replace the trans oil himself. Might even get us a new member
August 31, 200421 yr AT or MT. I'm going to assume MT. In this pic you can see the dipstick handle sticking out on the tranny in the corner http://www.main.experiencetherave.com:8080/subaru/images/legswap/04/DCP_3122.JPG better pic http://www.main.experiencetherave.com:8080/subaru/images/legswap/04/DCP_3123.JPG AT the differential dipstick is on the right, the tranny dipstick is on the left http://www.main.experiencetherave.com:8080/subaru/images/legswap/08/DCP_3217.JPG http://www.main.experiencetherave.com:8080/subaru/images/legswap/08/DCP_3216.JPG http://www.main.experiencetherave.com:8080/subaru/images/legswap/08/DCP_3215.JPG
